Why?mwgrient said:I would like to replace the potentiometer, jack socket and RCA terminals.
This is a function of the high input impedance of the amp, not the pot itself.mwgrient said:The potentiometer gives noise at the end of the volume (almost open wide)
Hmm, you'll have to maybe melt it off then to get it off.mwgrient said:The big black knob is not detachable since the screw is broken that will hold him in place.
Paul Birkeland said:you'll have to maybe melt it off then to get it off.
mwgrient said:https://www.youtube.com/watch?v=0OB8lpQ58lc
Is the adapter straight wire, or does it have a pad?mwgrient said:When I use a headphone adapter for the speaker-outputs, and plug in my headphone to the adapter it is wonderful!
No. How about a check of the DC voltages?mwgrient said:I am wondering: when is it advisable to rebuild the amp; from scratch?
You could, but at this point your amp already isn't working, so making more changes that aren't aimed at repairing the problem may just cause new problems.mwgrient said:Another wondering: can I eliminate de C4S Upgrade easily? Just the plane amp t keep it simple...
Check the DC voltages on the channel that isn't working and report any that aren't what they are supposed to be.mwgrient said:What would you do?
I suspect you have a broken wire, likely one of the ones connecting the C4S to the A side of the circuit.mwgrient said:A5,B5 - 298 / 70
A6,B6 - 0 / 2
A7,B7 - 0 / 2
We use essential cookies to make this site work, and optional cookies to enhance your experience.
