Voltages and resistances all checked out. A couple of the zero terminals had millivolts, but I assume that's ok and that I am just now noticing them because my meter is more sensitive.
In essence, you have a decent amount of signal at terminals 3 and 17. This signal is stepped down through your output transformers to your speaker posts. If it isn't getting through, I would focus on the output transformer wiring.
Should I just reflow the right channel output transformer joints and then try again? Are there any voltage or resistance checks to tell me whether there's something wrong with the output transformer itself?
Alright, reheated the OT terminals. Right channel is still completely out, left channel is very staticky. Swapped the tubes and the problems persist. Should I just ship it to you guys? I feel like I’m making things worse.
I found a broken orange wire (I break those Cat 5 wires constantly - any tips on how to strip them without cutting too deep and breaking them?) but it didn’t make a difference. All voltages still look good. Here are photos of the OT
I use an Exacto blade, I lay the blade on the insulation with light pressure and roll the wire under the blade. This will cut almost through the insulation, then use your finger nail to strip off the cut end of insulation. A little practice to get the pressure right and you can strip that CAT 5 wire without any nicks.
Ok. Hopefully I’ll get some time in the next couple weeks to devote to getting the left channel back. The only thing that’s changed there is the pot, so it should be easy enough to isolate. I picked up an extra foot of Cat 5 just in case.
I’m kind of baffled that everything was working reasonably well for a month and then just imploded. Doesn’t inspire a ton of confidence that I can pull off the builds for the Stereomour, Smash, and Reductor that I have boxed up and waiting to start.
These showed up last night. I tried them on a couple spare pieces of 24 gauge wire I had laying around… Wow! Really nice stripping. Thanks for the recommendation!
Our fiscal year ends tonight (thank god), so I shoul hopefully get some bench time on the amp this weekend.
Alright, I’m calling it. I reheated a bunch of joints on the right channel and nothing changed. Paid for the repair service since I’m basically just beating my head against the wall.
After you’ve done the repair, will you let me know what my error was?
