Quickie Upgrade [Solved]
    A mistake by me that no one could see. We now have music. Glorius sounding music, spinning 'Crises' by Mike Oldfield. The darn jumper wire on the A side was in the wrong hole!!!!!!!!!!!!!!!! Bring on the Bee Pre.
One pointer if you don't mind.  Print the manual in color, it makes things MUCH easier during assembly.  Btw, the BeePre is a loooooooong build, in case you didn't already know.
Glad to see you wrapped up your first kit and are enjoying it.  8)
Just another data point! I print the assembly pages of the manual in grayscale to make notes and check off progress.  I like to have the PDF on my laptop to be able to enlarge and zoom in on the pics for detail. A hybrid approach!  ;)  Especially helpful on the boards!
Geary
  All suggestions noted. Our printer's a lazer unit and only B&W. I did not have the wife double check my work. I use a 10x magnifier to examine details close up. Some of my solder joints, while cooling turn that dull silver look. I'm afraid of heating things up to much. Can damage occur to these fragile electrical components with to much heat soak?
  In the future I'll limit these all niter's trying to get er' done.
A better way to do it is to make a mechanical connection before soldering (half a wrap, then crimp with your needle nose pliers), then use a tiny bit of solder to fill in between the two. (like mortar in a brick and mortar wall) Using less solder requires a lot less heat.
If you just pass leads through the terminal holes, then expect to use a lot of solder to hold it there, you'll end up with an unreliable build that also won't quite sound as good.
  That's a great tip, something I'll never forget. As if this could sound better! I might just buy some terminal strips, a few resistors and a bit of wire and redo this part. I've already ordered some Clarity cap's MR Series as I can't leave well enough alone. It really pushes the Stereomour up a notch.
