rlyach
I was looking at the power supply schematic, and the transformer shows 160V for the secondary output winding. If I take this as the RMS value with 120V RMS on the primary side, I should get 225V p-p on the secondary side. Then, after the doubler rectifier I get 451V DC. The filter resistors for the 2A3 option are 1200 ohms in parallel with 360 ohms which is 277 ohms. The B+ on the schematic is shown as either 388V or 380V depending if you are looking at power supply output or the channel input. The manual shows 380V. Now, assuming ~54mA of nominal DC current draw, I calculate a B+ voltage of 436V. I must be missing something. I know that I will not get the full 451V DC on the secondary after the doubler, but there is still an discrepancy of ~50V. The only reason I am asking this is that I was going to install a single 1% 270 ohm resistor instead of the two resistors in the kit, and I wanted to calculate what power level resistor I should use.
