So...I completed my Quickie build this weekend. It turned out
VERY nicely, if I do say so myself. ;D
The deviations from stock are as follows:
1. I mounted the batteries on the underside
2. Installed a "ladder-style" stepped attenuator,
3. Installed 2.2uf ClarityCap ESA caps on the outputs,
4. Replaced the 1,000uf electrolytic caps with 100uf ClarityCap SAs,
5. Installed "upgraded" RCA jacks, and
6. Installed a power LED.
I used
this LED. It only draws 2mA, and the luminosity is 1.2 to 2.0 mcd, so it definitely isn't bright at all. The forward voltage drop is 1.9V.
Funnily enough, this might be one of those rare instances where a modification made it
easier to identify a problem in the circuit, rather than harder. When I first put the Quickie together, I couldn't get it working. After running various tests, I decided to try Paul's patented "chopstick" test. I poked around at various places in the circuit, and the LED immediately went on when I poked one solder joint in particular. It make it a piece of cake to identify the issue (it turned out that when I soldered one of the wires, it was inserted too far into the terminal hole, so that the solder flowed around the insulation, rather than onto the wire itself - I didn't notice this immediately, because it was a relatively crowded terminal with other wires that were correctly soldered at the same hole).
I'm very glad I installed the LED. Recently I've forgotten to turn off my tube amps a couple of times. While that's not a catastrophe, it's not ideal. At least those amps were wall-powered. If I do that with the Quickie, I'll need to swap the batteries, and given my mods, that is a relatively painful process.
I'll post pictures once I've finished the base. I also have a PJCCS on the way...I'm just hoping my mods don't make that a pain to install...
Best regards,
Adam
