I just re-read my older post regarding the 220v Paramount. I asked if there were any steps needed to anticipate the fact that the supplied transformer is 120-240v, while our line voltage here in Indonesia is 220v.
I got this reply from PJ:
"You are probably OK without any changes. The only thing I'd check on is the filament voltage.
When I tested the prototype (I just looked up my notes) I found 5.29 volts DC at 120v/240v. So, proportionally, I'd expect 4.85 volts which is only 3% low - well with even the 5% recommendation, and certainly within the 10% maximum tolerance. A low filament voltage does not becom important until the tube is well worn, so there is plenty of time to make changes if there are any problems. I don't remember what wire is used, but using a larger wire diameter (e.g. 16 gauge) will give the maximum voltage to the actual tube terminals.
If the actual voltage in use is too low for comfort, there are Schottky diodes with a smaller voltage drop than the ones in the kit; a simple change will raise the voltage. But as I said, you have plenty of time - a couple years at least - before you would need to do anything."
And then I read the sticky by PB regarding the additional capacitor between A1 and A4 pins, in case that the filament voltage is low.
I haven't got the chance to check the filament voltage, yet, I run the Paramounts with 230v currently.
But in any case which of the 2 methods should I follow, if my filament voltage turned out to be too low. And are the current 220v transformer different that the ones from 2012, since PJ calculated that even with 220v the filament voltage would stay within 3% of 5.29v (for 300B), at that time.
