Painting Metal Plate on Fully Assembled Crack
Oof, I mean. I can’t say I’d recommend it. That’s gonna be a lot of work to do that well and not damage anything. Important not to get paint on the bottom, especially on any components or near ground terminals.
As PB said, these don’t normally look great. Maybe your masking game is better than mine.
I swapped chassis plates of my Eros 2. So it’s possible to remove everything and paint the chassis. Although I wasn’t able to remove the AC socket, so that might need to be cut to be removed and replaced with a new one. I carefully desoldered the minimum number of connections and took off chunks of the circuit taking very careful notes so I could reassemble it. It’s quite a challenge, but it can be done.
