bosmaworks
Hi all,
I hope someone can help me with the following issue.
Some background info:
Currently I'm using the Eros to drive the Stereomour which in turn is driving 99db1/w/1m sensitivity speakers.
I'm using the Dynavector 20x2H high output MC cartridge which puts out 2.8V. Volume level is very satisfactory and actually playing way louder than my Bluesound Node2 streamer/dac. At least one click louder on the coarse control, maybe even more.
I would however like to increase the signal-to-noise ratio of the analog rig as hum and tube rush come into play at louder listening levels. Which is pretty audible especially during the quieter passages of music. I've ordered the Sowter 1090 SUTs to effectively double the output of the cartridge. I would however like to maintain the same amount of 'travel' on the volume control. Maybe even extend its travel slightly. So I was thinking it would be worth the experiment to pad the input into which the Eros is playing. I could do 6db to compensate for the doubling of voltage due to the SUTs but I was thinking of taking it a little bit further to approach the digital source a little bit more. Like 10db for example.
I would like to keep the input impedance at 50k so the Eros plays into the same load as before. I've looked at the Goldpoint charts at https://goldpt.com/preattenuation.html and found that for 10db attenuation into a 50k load I would have to use R1 53.6K R2 49.9K.
Using online calculators (which are all geared towards padding tweeter units) I end up with very different values. (R1 34K R2 23.1K http://www.mh-audio.nl/Calculators/att.html)
Could someone explain to me which resistors I would need to use to attenuate the signal by 10db while also maintaining the 50k load for the Eros.
I hope I'm not too much of a bother... I've looked everywhere and just can't seem to make sense of it all.
By the way, the Stereomour sounds wonderful with all its upgrades. It's a joy to listen to!
Thijs
Thijs
