Moderator
This question made me think, and I came to an interesting conclusion.
Technically, it is preferable to connect the outer foil to the lowest impedance point, usually the output of the previous item. That would be the 6080 cathode in the case of Crack.This allows any capacitively coupled noise (usually hum) to drain to ground most easily.
But Crack is an OTL, with an output impedance that is about the same as the headphones - in the range of 100-150 ohms. So again, at least technically and in theory, it won't make any significant difference - the impedance is quite low in either direction, and you don't know which is higher anyhow, unless you plan to use only one headphone and that headphone is either unusually high impedance or unusually low impedance.
