rlyach
Ok... This was a little more difficult. Using the JJ 2A3-40 datasheet I arrived at the following: The operating point is 59V at 49mA. I ended up making a spreadsheet to model the cathode resistor of 1194 ohms, and a plate load dc resistance of 600 ohms. Looking at the intersection of the resistors and the 2A3 tube I was able to generate a loadline. The peak to peak voltage swing of the 2A3 at full signal should approach 178V. I hope I did all that right. I understand that all these numbers a just paper calculations but it helped me to understand how all this stuff works. I started with a 2V p-p signal and ended up with a 178V p-p swing, giving close to 40db of gain. The 2A3 is an amazingly linear tube. Also the JJ ECC81 is much more linear than the original RCA 12AT7 I was looking at earlier. Now I think I am ready to build this thing. I was surprised at how large the 2A3 tubes were. Thanks for all the help and training. I now know enough to get myself in real trouble. I hope you guys will still be there to bail me out when I plug the amp in and it doesn't work...
