K.Boudreau
Hi. I'm hoping some of you can help me here. I posted this in the General Discussion forum, but mayby it belongs here. Anyway...
I have a full Bottlehead system that I bought and assembled around 4-5 years ago and have never had a problem with it until now. I have the Seduction, Foreplay, and the Paramour 2A3 amps that were available back then. They are stock except for I am running DC filaments on the Foreplay. I have never had any problems with hum or ground loops or any noise until now, and I haven't changed anything since I've hooked them up several years ago. Now, I have been getting an on and off again hum that jumps from one speaker to the next in a sort of ping pong, and sometimes both at once. With the hum comes distortion as if there is a drop in voltage. This tends to happen in the evenings and night for the most part from what I can tell, which makes me suspect some problem with the electricity in my building or neighborhood - but this could be just my imagination I guess. The system will sometimes develop this problem after the amps have been on and in use for several hours, or sometimes right after starting them up.
The Paramours have the C4S boards installed (I think that's what they're called), and normally when I start them up, last in the chain, there is around 15 seconds of hum as they warm up and then the hum instantly shuts off, which I assume is what the boards do, and is normal. My problem sort of sounds like the hum before the warm up, but with distortion and sometimes loss of audio. Again, this happens on both sides. I live in an apartment in a house that is over 120 years old with wiring dating from the early 1950s, at least, and I can't do anything about that, but I have the system plugged into a decent quality (not audiophile at all) powerstrip that is plugged into the two prong outlet with a ground lift adapter. The thing is, I have had it this way for years with no problems and haven't changed anything in my apartment electrically since I've had this system. Apart from a bit of tube rolling in the first year that I owned this system, nothing has changed and the performance has been flawless and fantastic. So...what can I do? Should I check the wall voltage with my DVM? Is the powerstrip suspect? Tubes going bad? Solder joint(s) going bad (remember it happens at the same time on both speakers)? Neighborhood or building power bad? Do I need a power conditioner? Everything?
Help please, this is driving me crazy!
