Grainger49
The voltage checks are typically from a point, terminal or PCB pad, to ground. PB is asking you to measure from one PCB pad to another. It just might be different.
The lower board IA (input to the A-side C4S) should be connected to the regulated voltage from the regulator board, so they can't be different - you are showing 225v on one, and 297v on the other. I assume this is a measurement error, since the highest voltage available anywhere off the PSU board is 273v (IA, IB on the regulator board) is 273v. Other than that, these all look quite good.harv-e said:Putting it all in one place for you:
Line 119.1
Power Supply Board
T4/5 8.5vAC T6/7 126.7vAC 6.3vDC measures 6.21 to pads (6.22 to ground pin 23) 275vAC measures 299vAC
Regulator Board
LEFT A side: bA 0 Kreg 9.0 OA 224 1A 273 breg 224 +reg 225
RIGHT B side: bB 0 Kreg 8.9 OA 224 1A 273 breg 224 +reg 224
LEFT lower Board Kreg 1.1 breg 95.4 OB 93.2 OA 158.5 bA 0 1A 297
RIGHT lower Board Kreg 1.1 breg 97.3 OB 96.6 OA 160.5 bA 0 1A 297
We use essential cookies to make this site work, and optional cookies to enhance your experience.
