rockpassion
I need some technical help with my BeePre. I replaced the 300b sockets which meant I had to take off the C4s boards and detach all the wires from the sockets. In checking the Resistance and Voltage everything is within the limits given in the construction manual. The one exception is terminal 17, the Voltage should be 90 - 110 Vdc. I am getting 0. I have checked everything a dozen times. I did find I had miswired the connections to B2 and B3, I had them reversed. I fixed that mistake. I checked the Capacitor connected to this terminal and it was within spec. At this point I do not know what to do next.
I do not know if this has any bearing on the problem. One of the reasons I changed the socket was how loose the 300b was in the socket. However, before I started working on this the 300b on the side I am having problems popped and flashed and I lost sound from that tube. I turned off the system and turned it back on and everything seemed to be ok. Although, not all the wires on the heater grid lit up and I also got a purple glow for a while inside the tube.
Any thoughts.
Thanks in advance for any help.
Richard
Any thoughts.
Richard
