Near field use on 87db speakers in a masive room.
In my opinion the 300B has a fuller sound with more weight to it then the slightly leaner more laid back sound of the 2A3.
I have a Kaiju which I use with a veriaty of speakers including some in the 85db range and I am happy with the sound...John
The iron in the Kaiju is also a bit better than the Stereomour, and the 5670 is the better sounding driver tube.
The Stereomour is possibly a bit easier to build because it is a bit simpler, but you also have to do all that input wiring to the selector switch which takes some extra time...
For tube rolling is there much variety in the 5670 tubes between brands? Or is the 300B more important for tube rolling?
They both make a difference, but I hear bigger differences between 300B tubes.  Tube rolling with 300Bs gets expensive, however.  But I found the expense of new production Western Electrics to be worth the upgrade in sonics and what I anticipate will be a longer life than the stock EH tubes.
It's pretty cheap to try different 5670s.  My Kaiju kit came with GEs, and they sound pretty good.  I've tried RCA, Sylvania, and vintage WEs, and none proved decisively better than the GEs.  In fact, the WEs were a distinct disappointment.
The WE 300Bs may well be a sonic upgrade. But I wouldn't necessarily assume the EHs to be shorter on lifespan. I typically get six to ten years out of one.
Interesting. Thank you all for answering all my questions.  I have just a couple more.
Is it possible to use 6SN7 tubes with adapters instead of the 5670 tubes? I only ask because I own 15 pairs of matched 6sn7 tubes.
Does the DC upgraded change the sound characteristics of the Kaiju?
Later on of I decide to upgrade the caps on the Kaiju. Which ones would be worth upgrading?
It would be possible to use 6SN7s in Kaiju, but you'd need more modifications than just an adapter. You'd also lose 6dB of gain.
The interstage coupling cap (0.1uF/630v) and parafeed output cap (10uF/630v)are the principal caps that are in the signal path. The shunt regulator stability Zobel cap (also 0.1uF/630v) also has has a minor effect on the sound,  but it's on the regulator PC board and difficult to access.
These caps are subject to break-in changes, so allow at least 100 hours of music before critical listening.
A 6db loss seems like a lot. So probably not worth it to change to a 6SN7 tube input. How does upgrading the caps affect the sound? Should I wait to do the DC upgrade till I've put time on the amp?
Changing the caps will - subtly - change the sound. Whether it's an upgrade or a mistake is difficult to generalize; it depends too much on personal reaction. There is some consensus on the interwebs, but it changes often. I personally think the best benefit of cap rolling is that it educates your hearing, and you learn what you like. That's just my two cents though.
It's usually a good idea to build an amp stock first and run it for a few weeks. This gets it through break-in, educates your ear as to the baseline sound, and it helps catch a lot of small errors such as dirty tube pins, marginal solder joints, loose screws, etc. And it's much easier to debug any problems after a change when you know for sure it was working correctly before the change.
What varieties of the 5670 will work for the input socket on the Kaiju? I read in another post that some of the varieties aren't rated for high enough volts.
Will pretty much any of these tubes types work? I think this is full list of comparable tubes.  396A, GL5670, CK567, 2C51, 6CC42, 6Н3П, 6N3P(EV, DR), 5670W, 5670WA, CK5670-WA, CV4013, GB-5670.
Do you have a link to the post about the varieties with insufficient voltage rating? (or which tube is not supposed to be adequately rated?)
Paul Joppa said:
Be aware that the maximum plate voltage rating of the 6n3p is 160v, whereas the 5670 is rated for 330v. In Kaiju, the regulator section runs at 300v, and the amplifier section at 175v. Use of the 6n3p will risk failure of the tube and collateral damage to other parts of the amp.
I'm not certain where PJ is finding that number, as the 6N3P  shows 300V is acceptable for plate voltage:
https://frank.pocnet.net/sheets/113/6/6N3P.pdf
I've gone cross-eyed at times trying to keep Russian equivalent tube types straight in my head, so perhaps there's another tube that's maybe a letter off with that restriction, or there's a different grade that's derated, or even a conflicting datasheet out there!
I have edited that post today. If you read the posts that follow it, you'll get the full story. It's complicated.
Sorry for the confusion, I should have edited the post earlier.
So the E suffix ends up being the issue it seems, or perhaps the derated voltage is part of the trade for longer life?
Are there any input tubes that can be used with just an adapter or would anything besides the 5670 line be a sonic downgrade? Does the Kaiju require a pre-amp?
Kaiju was designed around the 5670, not with alternative tubes in mind. Most candidate drivers will need changes to the voltages and currents; some will also require an adapter. I looked at quite a number of candidates to pick the 5670, but have not done the detailed calculations for any alternatives, so I can't at this point say which might or might not be made to work out.
Sonic upgrades and downgrades are so much personal taste that I can't usefully comment.
Kaiju will usually need a preamp in most systems. There are exceptions, but not that many.
BeePre2 works well with lots of amps and, yes, it is the mate to the Kaiju.
