D
Guest
I've finally gotten around to the final rebuild of my Beepre in a huge aluminum chassis (that I call "Bigby", as in "big bee"). One of the challenges was figuring out how to deal with the extra height of the chassis - with feet and tubes installed, it wouldn't fit my rack. So I figured I'd make big cutouts for the tubes and install the sockets about 1"+ below the top plate. And then it occurred to me that I could mount the socket subplate so that it is sandwiched between thick silicone washers: bolt head, steel washer, silicone washer, subplate, silicone washer, steel washer, standoff. To minimize (hopefully eliminate) vibration transferred from the bolt threads to the subplate, I wrapped the top 3/4 of the threads 2-3 times in electrical tape -- just in case the side of the bolt makes contact with the inside of the subplate mounting holes. I'm hoping the combo of ptfe sockets and the additional damping will give the 300Bs extra isolation from any chassis vibrations.
Here's some pics. I punched the silicone washers out a sheet of 3/16 silicone.
But it occurred to as I was putting it all together that a simpler and better approach would have been to really oversize the mounting holes on the subplate and install thick silicone/rubber grommets. Ah well ... next time.
cheers, Derek
cheers, Derek
