Moreplay paired with S.E.X 3?
The SEX 3 is going to make the same watts either way. What Moreplay does is add gain up front so you’ll reach that full 2W of output with less travel on the volume control. If you’re already able to drive the amp to full output, you shouldn’t expect it to play any louder.
If the goal is more volume or headroom, that’s an amp or speaker change instead of a Moreplay addition. The SEX 4 and the Stereomour II both have about double the output of the SEX 3.
