Doc B. said:Those switches are way too small. You should upgrade to something like this.
guildenstern said:I'm hoping one of you technically savvy forum members can help. On Head-Fi I bought a modded Crack from a BH forum member -- great build and very enjoyable sound. What I can't get from the builder is a clear explanation about which way the switches should be set for 12AU7 and which way for E80CC. Here are pictures of the resistor switch assembly he devised, taken by the builder of the amp. If you can use these pictures to deduce the proper switch positions for 12AU7 vs E80CC, I would appreciate it. Especially if you can explain in "for dummies" terms (as I readily confess I am). Thanks in advance.
Maxhawk said:In the speedball circuit there's a series resistor from B+ to the 2N2907 transistor that sets the current flowing through the tube. The stock 12AU7 uses a 238 ohm resistor while the E80CC requires 470 ohms. In the photo you can see that the switch is connecting a 470 ohm resistor in parallel with the resistor on the board (which looks to be 470 ohms). When the switch is open it's set for an E80CC. When the switch is closed, it's set for a 12AU7.
I'm not familiar enough with rocker switches to tell you which position is which (I only know toggle switchs). You can take a DVM and measure the resistance on the switch between the middle and right terminal. 470 ohms = E80CC and 235 ohms = 12AU7.
The circuit and part names are identical, so it should be exactly the same to build this out on the newer Speedball.Clair-de-Loon said:Any hints?
Paul Joppa said:.....
You may have noticed the substantial opportunities for confusion here! :^)
What would be called the "plate voltage" of the 6080 would be the difference between plate and cathode voltage on the 6080.Cornysh said:How do you calculate the size of the Va of the 6080? Is it simply a matter of subtracting the Va of the 12AU7 from the total B+?
We give bias in voltage. The bias with the Speedball is a variable to solve for. Current is held constant at 30mA. The bias voltage is the conclusion to the work, not the starting point.Cornysh said:Bias = 30
Yes, plate to cathode voltage on the 6080 is about 70V. From the curves, you would get from this that bias voltage is about 30V.Cornysh said:Va - Vk = 70 (determined from curves where plate voltage + bias = 100)
If the grid voltage is 70V and the bias voltage is 30V, then the actual DC voltage at the cathode is 100V.Cornysh said:Vg = 70 (supplied from plate of 12AU7)
Vg - Vk = Bias
70 - Vk = 30
Therefore Vk = 40
We use essential cookies to make this site work, and optional cookies to enhance your experience.
