ianp said:Below are some links I have saved for these mods that I intend to do at some point.
For broken links and particularly for images I quite often just do a google image search for something relevant in the threads
Bridge Rectifier
You don't really need the PCB as the circuit is as you would expect and you can replicate on prototyping board or similar.
NB There are reminders that the tabs on the top of the diodes are live and should not touch anything ever.
- PCB - https://www.partsconnexion.com/PCB-77727.html
- Cree Diodes https://www.mouser.co.uk/ProductDetail/Wolfspeed-Cree/CSD01060A?qs=%2Fha2pyFaduha8e7L7P6H8AQPAaWzRYR18hPNYjU5%252Bzc%3D.
- Wiring guide - https://cdn.head-fi.org/g/9937481_l.jpg
Choke
- https://www.mouser.co.uk/ProductDetail/Triad-Magnetics/C-7X?qs=sGAEpiMZZMuMS2dUaCDnDB57UyZo4e84
This replaces one of the two big white 270 Ohm 5W resistors. Most people seem to replace the one between 13L and 15L
Deke609 said:Maybe you could just make one with protoboard using wire in place of the traces as Ianp suggests in the quote?
Or maybe the axial style recitifier board (in stock at Parts Connexion) could be made to work by bending the leads of the diodes? https://www.partsconnexion.com/PCB-77726.html
oguinn said:The extent of my electrical abilities extends to poorly soldering and following extremely explicit directions written by people way smarter than me; I'm not sure I want to take on protoboards since there's a 95% chance I'll solder my dog to the amp by accident.
I've got some feelers out for the actual PCB, but I might give the other version a shot. Or maybe get the pre-built one and yank out the existing diodes.
carlman14 said:Reviving this suggestion to see if anyone knows. The "Discrete Bridge Rectifier PCB - TYPE 2 (TO-220 Radial Style)" seems to be perpetually out of stock. Does anyone know if that axial version of the rectifier board would work for the cree mod? I can't find any posts of anyone actually using the axial board...
They are ultimately pretty similar to the 600V/1A parts. The minor differences are not worth the dramatically increased price IMO.tim273 said:There's some new Schottky Diodes available on Mouser, would one of these work instead? If so, better or worse then the previous version?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
