Hi all,
Having excitedly just pulled the trigger on the current Mainline sale (despite lusting for a LONG time), I was curious to ask what possibilities there are for integrating the Mainline into a wider 2 channel/headphone system.
I apologise in advance for the noob questions I'm about to drop!
I'm keen to co-locate and if possible integrate the Mainline into my current 2 channel system as much as possible to limit swapping sources etc based on my listening scenario.
I have previously seen people mention running the Mainline as a preamp into a power amp. (First noob question) is there any reason I wouldn't/shouldn't run the Mainline output into my exposure Integrated amp? My thinking here is I could input my DAC output and phono output into the Mainline and listen via the balanced out for headphones and switch to the SE out if I wanted to listen via my speakers. Essentially this is just to avoid adding some kind of switching unit to my sources.
(Second noob question) what would happen if I ran my turntable straight into the Mainline? Is it capable of acting as a phono stage or can it be easily(ish) modded to do so?
Please be gentle, I'm new!
Paul Cawley
Paul Cawley
