i have a crack with speedball 1.1 which the left channel hisses very loudly on (volume all the way down). if i turn up the volume with a source plugged into it hiss is not really noticeable due to the music playing. the left channel is a about 10% weaker than the right channel.
ive went through the troubleshooting guide in the manual i found online and checked all of the readings readings. i cant seem to get any readings on B3 and B6. also, the led going from a3 to center does not light up. other than that, ohm/vdc are all within 15%. b3/b6 vdc reads properly.
the a3 led will blink a few times when i plug in a different tube there, tungsol 12bh7a. doesnt do anything at all with the stock. b3/b6 ohm readings with a tung sol 5998 vs stock rca 6080 is the same as well.
full disclosure, i bought this pre-built from someone on ebay and after seeing the horrible soldering work close up i probably should have just built it myself. also, all of these issues didnt start happening until i had it for 3 or 4 months. it would occasionally hum but that would be corrected by slightly moving one of the tubes. the led lighting up on a3 , im not sure if its always done that or not, didnt notice it until i started troubleshooting.
