Left Channel is slightly louder than the Right [resolved]
I Just tested the voltage on 33 and 37 again with Both Tubes installed.
I got 5.7 on both terminals. on Terminal 33 if I touched the middle of the terminal I get  00, but if I moved towards the top and bottom of the terminal I got 5.7. I checked again as the tube heated up a bit, and it was more 5.8 and 5.7 fluctuating
I am playing an albums right now to test. It is NOT distorted, it sounds great :o. I am thinking maybe when I re flowed I knocked the 22 ohm resistor out of wack. I noticed  terminal 38 was not touching the terminal tightly, so I fixed it. The Balance seems proper now as well. So I think I am all good. If you don't hear from me it is a good thing.
I really, really appreciate all your help with this , I would have been lost without your service. I am thinking about upgrading and getting the C4S kit to go along with my reduction. If things go bad with that you may see another post from me. ;)
Thanks again, always great service from Bottlehead and I always recommend you to fellow audio enthusiasts.
I'm glad you got it sorted.  A lot of issues like this boil down to either flaky solder joints or weird hardware issues (sometimes both).
