What are you going to use those for? They don't seem related to repairing your Speedball.denti alligator said:OK, thanks.
Any chance these resistors could work? I can't tell the wattage.
They aren't exactly the right value either.denti alligator said:I was hoping I could use them in place of the wirewound resistors, but obviously they aren't the right wattage.
I'm not getting a voltage reading at terminal 2. How long should I wait? I don't want to destroy the resistors again. I've left it plugged in for about 6-7 seconds. Voltage hovers around 0.02Caucasian Blackplate said:Replace the 270 Ohm resistor, then run the amp without the 6080. Use a pair of clip leads to have your meter reading the voltage at terminal 2 while you turn the amp on. If this voltage drops below 130V, then turn the amp off and report back.
There should be a number on your meter, what is it?denti alligator said:I'm not getting a voltage reading at terminal 2. How long should I wait?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
