Kit Assembly Gallery
Love that black finished Crack.  Woodworking has been my main hobby for years and I have had good luck at ebonizing oak and ash with a simple process. Obtain some black dye from a woodworker’s store, a water or alcohol base dye works equally well, but may have to re-sand if the water base raises the grain.  Apply 2-4 coats of dye, let it set for at least a day then apply a standard black stain (like Minwax ebony).  As a finish coat rub in some Tried & True varnish oil, the more coats you add the glossier it gets.  Adding the standard black stain helps pop the grain and give it an ebony like appearance.
Jim G.
Here is a Kaiju I built for personal use.
Now that's a fine looking amp. I like the combo of black metal with deep brown wood sides.
Very nice, Derek
Are those covers sitting over the regular transformers or are there custom parts i there? If it’s the former… where can we get those?
I didn't have much faith when I saw that purple heart lumber. I stand corrected, that looks really nice!
Here is a green Stereomour II that I just completed for a customer.  It is setup with a 4 pin balanced headphone jack up front for driving power hungry headphones off the speaker outputs.  The customer opted for the DC filament upgrade to keep it super quiet, as well as the shunt regulated driver supply.
Very nice.  45 or 2A3 (or both)?  Either way, I think the purchaser will be very happy.
cheers, Derek
Hello
  I have a S.E.X kit that I have 1/2 assembled that I need to get done.  I don't have a space to work on it anymore is this something you can help me out with?
A powder coating gun and an oven!
For powders with any kind of metallic particles, the Harbor Freight gun is pretty decent.
I feared so. Out of my league for now! Looks to be worth a try on the next project. Truly inspiring builds PB.
