polytrigon
So I assembled the S.E.X 2.1 about 10 years ago with my father. He was an electrical engineer in a past life and was very knowledgeable and skilled at getting it all in one piece. Flash forward to now and i've finally gotten around to putting my phono back to use and I had forgotten that there was somewhat of a hum when i plugged in my apple hifi to the headphone jack.
Now as a disclaimer I am a junkyards wars kind of EE, I have very little knowledge but have soldered a ton of drones and other doodads so if you show me a wire diagram I'll pass out, but if you ask me to solder some bits together I'll do so without burning myself. What I'm trying to say is that I'm a noob so please feel free to talk to me like you're talking to a baby elephant. I do however have some experience troubleshooting so I'll just lay out the information at my fingertips.
I've since ordered the C4S kit, hoping that it further reduces the hum but in the meantime I wanted to see if this is just normal or if I've done something wrong.
Oh I also went through the forums and read a bunch of other threads that sound similar. I checked all the solder joints and use a chopstick to poke at everything to make sure that it wasn't a bad joint.
- phono turned off
- apple hifi plugged into headphone jack
- tubes in
= 60hz hum (what sounds to me as the 60hz hum, I've listened to some youtube videos and it sounds similar)
Additional notes:
- if I adjust the volume the hum does not increase or decrease
- if I remove the tubes the hum goes away completely
- I had a handful of tubes and i went through different pairs and found one specific set that has significantly less hum
- There were tubes that I plugged in that once they warmed up had a VERY pronounced hum... when i turned on the amp i could hear the 60hz hum and then after about 10-20 seconds when the tubes warmed up there'd suddenly be a much louder hum.
So with this said does it sound like maybe I just have some bad tubes and need to get different ones / allow this "okay" set to break in?
Thank you in advance!
M
- phono turned off
- tubes in
Additional notes:
M
