installing Beequiet as I buiuld Beepre- voltage tests still still accurate?
kip.duff
Member
I'm at fork in road where I'm installing volume control wiring in my BeePre.  I would prefer to go straight to BeeQuiet install as part of Beepre assembling.  Will the voltage tests for the stock Beepre in the assembly manual still be accurate?
I would suggest that, if you are unsure of whether the testing of the circuit is valid with the shortcut being installed during the initial build it probably makes sense to build the amp stock, make sure it passes all the tests and then install the upgrade.
