Hello,
I am eduard from the Netherlands . a long time audiophile but lacking skills to predict the outcome of connecting a power transformer, a rectifier tube , some chokes and some capacitors. So i just have to connect and listen.
There are however some things that are usually confirmed by things i built so far or to which i will stick to just for safety.
I will write them down randomly.
Untill now no matter if it is a tube design with low current or a solid state that takes 1A choke input with the right numbers of henry and a proper load resistor always is a good start.
Differences between chokes used for choke input are big. Not only comparing one brand to another but also going up in Henry . There are brands where you can choose for a smaller airgap so more H but less current capabilty but same DCR and the bigger H will sound better.
A transformer with a lower current rating and a choke with more H will be better than a bigger transformer with a smaller choke.
I have been building choke input supplies without calculations ( just did the load resistor and critical inductance) and start looking at PSUD some months ago.
I have been told that behaviour during start up isnt that important( unless you overload the rectifier) BUT the important thing to look for is how the last stage reacts to a stepped load.
It appears that using high henry chokes sometimes forces you to use more mF to stop strange behaviour. One would think that using more Henry ( i start doing this to be able to just need a very tiny amount of current for the load of the resistor compared to the circuit load) would make it possible to use smaller mF caps.
In the supply there are caps whose main task is to filter and there are the ones that act as a reservoir. Some people say in order for the supply to be quick the caps must be low value. So quick discharge and recharge. But if the last stage of the supply has serious mF the amount of energy available is bigger so the recharging could be a bit slower or not?
I start collecting some caps that i am going to use in a 620 volts dc that needs to supply maximum 70 mA to a stereo DRD with Vt25A tubes that will just be used for 600 cycles/hertz ( 12 db filter at line level)
I have Eyuda caps containing oil, Epcos MKV, some CSI 10mF ( which are made for the military but i know nothing about them) and some Russian 50mF
caps which are similar to the k75-10/k75-24 which are on the way to me. I have send one Eyuda to a friend and he tried them as the reservoir cap with different by pass caps so far K75 gave the best results.
It could well be possible that as the first cap after the input choke another cap could be better.
At first i wanted to use an LCLC supply and after the last C give each channel its own LC stage. After rereading Jean Hiraga articles from the eighties where he wrote if that makes a difference than the original supply wasnt good enough. His advice then was to add more caps ( it was for a phono preamp) not improve current capability but to reduce ESR ( of course they are related)
If i would go for LCLCLC i could go different caps for each stage. The Epcos and The Russian are both a mix of paper and some plastic foil. The MKV contain like a spoon of oil. The K75 are more like impregnated with oil not like a bathtub.
Any ideas or suggestions are welcome.
Thanks in advance and greetings, Eduard
