Yesterday, I wanted to swap some tubes and I put some regular ones (not coin-based) to make burn-in faster with some other, probably non-matching tubes. Here is what happened: After putting the new tubes, I realized that the sound is not coming from one channel, so I assumed that tube was faulty (although I must say that I did not try it with old tubes before the swap, however it was working fine before). I swapped the two tubes, but the problem remained. I put the old working ones, no difference. There wasn't any sound coming from one side. This was at the night time and I was really mad. I postponed opening the amp and checking the resistance and voltages to today. I just finished testing just a while ago and to my surprise, everything checked ok, both voltages and resistances. Only thing to mention will be that I read 1.5V AC in power terminal 2 instead of 0, but I am guessing this is ok as well. Every reading is within limits (the differences are usually less than 10% of the given values in the manual). With the resistances I read 220Ohm at A4 and B4, which is not matching the manual, but I remember reading somewhere that these values might be wrong, I am not sure where though... However, the readings in both channels are matching to each other anyway... This actually surprised me a lot. I was expecting to find some mismatch in both channels. Anyways, after this, I decided to use a more sensitive pair of headphones to test if there is even some sound in the left channel (I had problems with left). I used some crap earphones, which came with an mp3 player, however I knew that they are much more sensitive, so they were suited for this last test. Interestingly, there was some sound in the left channel. I could hear from both left and right, although left one is attenuated much more than the right channel so that I thought at first, there wasn't anything coming from there. The speaker posts behave the same probably, but again I can only hear from one side, my speakers are not sensitive at all...
So, what might be the problem, what do you recommend?
