Hum Pot adjustments [resolved]
I don't see anything in there.  A higher resolution meter and a 60Hz tone will be required to figure out which half of the amp to look at I think.
Ok sounds good! I am happy to start running a test after work tomorrow and I should have everything by then. Is the tone an audio file? When you are able to, let me know the first steps so I can report back once I have the opportunity.
Upon further inspection, it looks as if A5 and A4 were potentially touching, would that cause the problem? All of those terminals move around a bunch so not sure if it was leaning up against it.
If A5 and A4 touch, that will also throw off the DC voltages, but certainly I would do some trimming if they look close.
The first test you can do with the amp off, which is to measure the AC voltage between the center post of the 9 pin socket and ground (you can use the shell of the RCA jack) with the trim pot all the way up.
I typically use a free tone generator app on an old phone to get the 60Hz file.  You can also use a laptop with a headphone jack and grab a tone generator webpage.  Your DVM will read 60Hz AC, and typically I'd expect about 0.3V of signal to be available.
Once I get the meter, I will measure this! Should all tubes be in place for these tests? Is the tone playing in this test or no?
Yes, the meter will measure the 60 Hz tone as AC voltage.
For the first test, the tubes don't need to be in and the amp can be off.
Hey,
Just did the test, am reading .191V of AC going from the center pic of DSocket and using the RCA grounding jacket as the other point.
Assuming you have about 200mV of signal at the center pin of the RCA jack, the next step is to fire up the amp with the tubes in it and check the AC voltage at pin 3 of the 300B tube socket.  A normal working amp with the trim pot turned all the way up and 200mV of signal at the input is going to give something like 5-6V of AC signal at pin 3.
If the AC voltage appears at pin 3, you will then want to measure the AC voltage across terminals 5 and 10 of the output transformer (these have the red/white twisted pair of wires connected to them).  If you have 5-6V at pin 3 of the 300B socket, you'd expect to see 3-4 times that across the output transformer.  You have to move the black probe because the output transformer primary is sitting at about 70V DC, and your meter may not see the AC voltage through that.
Getting .241V of AC from center post of RCA to Grounding jacket. I need to head back into work, but will be running the next test once I get home around 630 EST!
Thanks so much for your help!
When I am checking the voltage of these pins and terminals is the blackprobe staying on the RCA grounding source? or is it moving to other areas? WHat do you mean move the black probe?
If that is a correct measurement would it make sense to assume that the problem could be stemming from the Beepre? I tried playing both the Beepre and Kaiju for the first time in the same go.
1.133V AC is audible signal coming out of the speaker jacks. This confirms that the amp is working.  I would hook it back up and have a listen.
No right channel still. So we can assume the Kaiju is fine? Other thing is a BeePre2 I built right before the Kaiju.
Try swapping cables from the beepre 2. If the problem switches sides the amp is good and you need to focus on the cables or preamp.
