Natural Sound
Active member
I'm in the final stages of preparing my Crack chassis plate to use a 6SN7 as the voltage amplifier. As you know the octal socket does not have the center tab used on the miniature socket for grounding the LED's. How critical is it to have the LED's close to the socket pins? Is it OK to install an additional terminal strip to mount the LED's and then use wire to go to the sockets? I happen to have some three pin center ground terminal strips in my parts bin that should do the job nicely. I ask because other Bottlehead kits I have built stress that the grid stopper resistors be mounted with the resistor body close to the tube socket pin. I was wondering if the HLMP6000 mounting was similar. For what its worth I plan on mounting the new terminal strip as close as possible to the socket. I'm thinking it should be fine.
