High Voltage
Toys4Boys
I am reading 260V-280V on the legs of the MJE5731A transistors, double checked my connections and can't see any problems.
went back to the transformer wiring, traced my connections and double checked my readings at which point I realized that the 275V out from the PS was in the printed limit. Guess I need to go over my shunt board again.
What are your Kreg voltages?
The +275V of the power supply board will go higher if no current is being drawn from the power supply.  The MJE5731A collectors will also be much higher than they are supposed to be if no current is being drawn through the circuit.
Yes, the 12AU7 needs to be installed to test the board that lives above the 12AU7.  You can slip your black meter probe into the ground post so that you don't have to hold it.  The red probe should measure DC voltage on each Kreg pad.
Definitely do not try to probe the legs of the transistor.  It's tough to do and if you short two legs together, more damage will occur.
You have "Center" being the middle leg at 218 and 219, does this voltage also appear at the metal tab of the transistor?
Damn, I misunderstood the instructions and checked the legs of the transistors not the tab  :-[ , I'll check in the morning and let you know.
The tabs measure out fine, I'll chalk this up to an opportunity to double check my wiring, found a couple untrimmed leads and 1 connection that I hadn't soldered. Also for future work read then reread the instructions to make certain that I am clear.
