Hi,
If this needs to go to the general discussion section, apologies, but just a quick question. I posted a question about which amp to go with and I thought I was pretty much set. A few days later I have a few doubts.
The Stereomour goes to 3.5 watts per channel. My 96db sensitivity speakers live around 1/3 (moderate level listening) to 1/2 (probably a bit loud) on a 6 watt per channel (into 8 ohm) T-Amp, so that's AWFULLY close to that 3.5W threshold. (Assuming dial position corresponds to % wattage).
Is the Kaiju a better option? If the only difference is that cost in the standalone amp, then I was considering it as a good alternative. But I noticed it didn't say integrated amp, does that mean I would NEED to have the preamp as well?
Martin
Martin
