First startup ... Pls Help!
Neither of your high voltage regulators are working appropriately. Are you able to set the bias voltage for each 6C45P as directed in the manual?
What are OA and OB on the center PC board?
The 1V at Kreg and 300V at Breg means the 12AU7 in the middle is sucking down nearly limitless current.  The simplest way for this to happen would be a wiring error on the high current C4S boards.
i am not sure what u mean by the OA & OB on the center pc board.  the OA connection of the center pc board is a white wire connected to C1.  the OB is connected to A6 if thats what u mean .
I would add some solder and a lot more heat to all the solder joints on those boards except the ones where LEDs connect.
hi Paul,
these r the results after re-solder every contact on all 3 boards.
IA A and B 274v
6.3 57v
-6.3 52v
275 275v
Biasing 1.45v
Breg A 273v
Breg B 216v
Kreg A 1.18v
Kreg B 10.66v
OA 1.76v
OB 2.02v
Resoldering your connections brought one side into proper operation.  I would suggest that you also resolder the center PC board and perhaps that will fix the other side.
hi Paul,
after replacing the A side LM431ACZ ,  the results remain unchanged.  what do u suggest I shall do next?
