In an earlier post PJ clarified that the EF86 cathode current in the Eros is controlled by a transistor to enable the newer variants of EF86 to bias properly. Would you then be able to use unmatched tubes without issue. I would guess that would be the case, but wanted to check before I put some tubes with widely varying values [but both test over 100%] in my Eros.
thanks
Bryon
thanks
Bryon
