DrewTube
My Eros -> EFP3 rig has too much gain. Like ~40 dB too much gain (high output moving magnet cartridge). Without additional attenuation, I have to put the preamp on the absolute lowest volume setting to even be a tolerable listening level. I have a string of three -12dB Harrison Labs audio attenuators on the input jack of each channel of my power amp, which brings it down to much more manageable levels and lets me put the volume control in the "sweet spot" toward the middle of the dial. However, it seems dumb to have 8 inches of attenuator barrels dangling off my power amp (and seems to be asking for me to break off the RCA jack with that giant lever).
I have an RCA connector barrel that will let me put my own resistors in there, so I figure I can make a single L-pad shunt attenuator with my needed ~40dB of attenuation. There are many combos of series and shunt resistors that will accomplish this, so I guess the question is: what is the ideal impedance for my attenuator? 10K? 35K? 50K? More?
From the EFP3 manual, it says the output impedance is 700 ohms and recommended output load is >10K ohms. My solid state power amp has an input impedance of 18K ohms. Connection is via unbalanced RCA interconnect.
