PassionForSound
Hi all,
Back when I used to design car audio systems for sound quality, I used a trick where we would use a separate amplifier for each channel (i.e. amp 1 would use its 2 channels to separately drive the woofer and tweeter for the left channel and amp 2 would use its 2 channels to separately drive the woofer and tweeter of the right channel). The outcome of this was zero crosstalk once the signal left the head unit.
I'm wondering if it would be possible to replicate this on the S.E.X. and / or if it would bring any benefit.
As far as I can tell, this would simply require running my headphones from the speaker terminals via a 4-pin XLR or similar adapter and possibly disconnecting the heapdphone jack because it seems that until the earth is shared on the headphone jack, the signal paths are completely independent. Is that correct? And if so, will there be any benefit in terms of reduced cross-talk?
