Hi!
My first Crack build went perfectly, all voltages good, and the resulting sound absolutely brilliant. After a couple of weeks, a crackling sound started to appear. It seem related to the large 6080 tube; wiggling it changed the crackling, occasionally causing a loud hard pop. Leaning the tube slightly made it disappear, so I disregarded it for the time being.
I then went along to build the Speedball upgrade. Again, it went without problems. However, I missed having the voltage numbers based on my 230 V input here in Sweden. Some readings were rather high, but they matched the relations in the manual. So I went along and started to listen, and the sound was again great, I believe with an even firmer base.
The problem is the crackling, which became more and more frequent, now making it impossible to use. I have cleaned the pins on the tube, and re-soldered all the wires attached to the socket. Wiggling the tube still affects the crackling. Is all of this simply because the tube is damaged, I wonder?
