I built a Crack about 7 years ago, no issues and I still to listen daily. A friend bought me another Crack kit and I figured I'd try some upgrades. Spent almost 3x as long to build as the first one...and there are issues. Go figure. :
I plan to install the speedball later so temp mounted the caps with extra long wire.
Passed initial voltage test
Passed glow test
Passed resistance test
Failed last voltage test, led not lit
1: .003v
2: .002v
3: .001v
4: .002v
5: .003v
6: .001v
7: 1.2v
8: .001v
9: .001v
10: .002v
I redid the first voltage test
6.2v at Terminal 9
175.3v at Terminal 12
Tubes glow
Per the manual and Paul's typical advice, I will reflow all the joints tomorrow aside from A3 and A8. If that doesn't resolve, I will put the stock caps in and remove the Wima bypass. If anyone spots any other issues, I'd greatly appreciate the help.
The manual states we should fill all unused terminals on the sockets. Is this necessary? I dont want the solder flowing down to the bottom-hole joint.
Thanks in advance.
Passed glow test
1: .003v
2: .002v
3: .001v
4: .002v
5: .003v
6: .001v
7: 1.2v
8: .001v
9: .001v
10: .002v
6.2v at Terminal 9
Tubes glow
Thanks in advance.
