Moderator
The BeePre can't get below 600 ohms on its own, so damping factor of 1.0 for 600 ohm phones, worse for any others. So I mentioned the possibility but can't say if it will actually work out.adamct said:Paul,
I've thought about it some more, and I would actually be interested in pursuing the idea of using a modified BeePre as a headphone amp, but I would need help figuring out what mods would be necessary. Is that something you would be willing to do? Or is this a stupid idea that should be laid to rest?...
Doc B has several Senns, so does PB I think - let's let them do some critical listening before we get carried away. The only mod I was proposing would be to install a headphone jack.
If it can't be done without a transformer, we have a few different approaches using transformers. I expect there will be a higher end something, eventually.
