Paul Birkeland said:I would start by checking the resistances and voltages.
Paul Birkeland said:Yeah, that black wire to A3 is a problem.
The wiring on the power transformer will depend on your incoming voltage. You have your transformer wired for 240V mains, where do you live and what did you measure with your meter during assembly?
The joint at 16L needs more solder.
20L needs more solder.
21L needs more solder.
Paul Birkeland said:That black wire is not where it's supposed to be. I would not plug the amp in when it's wired like that.
It's also not wired for 230V, which is a different configuration that is available.
I would send this back.
Or you could move one wire and see if it works?Coldsnap said:I'm going to rebuild it.
Paul Birkeland said:Or you could move one wire and see if it works?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
