Mucker
Member
I have been using a very powerful Emotiva XPA-2 Gen 2 stereo power amp to drive high efficiency Klipsch RF-7II speakers:
Frequency Response 30Hz-24KHz ± 3dB
Power Handling 250W RMS / 1000W Peak
Sensitivity 101dB @ 2.83V / 1m
Nominal Impedance 8 ohms compatible
High Frequency Horn 8†square 90° x 60° Tractrix® Horn
High Frequency Drivers 1.75†(4.45cm) Titanium diaphragm compression driver
Crossover Frequency 1200Hz
Low Refequency Drivers Two 10†(25.4cm) Cerametallic™ cone woofers
Inputs Dual binding posts / bi-wire / bi-amp
Enclosure Type Bass-reflex via dual rear-firing ports
Height 48.5†(123.3cm) with feet
Width 11.6†(29.5cm)
Depth 16.3†(41.5cm) with grille
Weight 87.1lbs (39.5kg)
I have no plans to change from these speakers but recently tried my S3X amp with them and was very happy with how it drives them.
My dilemma now is that I am really wondering how much better a Stereomour II would drive the Klipsch. From a volume standpoint, I don't need much more than the S3X provides. However, I would desire possibly a bit more weight in the sound, particularly with the bass. A few more dB power with slightly more bass would really nail my needs. Cost does come into play and I want to make sure the jump to Stereomour will get me to where I want to be. Any comments, and or suggestions, is greatly appreciated.
I have never heard a 2A3 or 300B amplifier before but would like to experience one if the leap is big enough. Thank you!
Width 11.6†(29.5cm)
