mercury128
Hi
I just completed my Crackatwoa build. For one of the inputs (closest to the power transformer, RI3 and LI3), there is a severe channel imbalance. If the balance knob is kept in the "middle" position, which is sufficient for the other two inputs, there is almost no sound in the left channel. By turning the balance knob almost all the way counter clockwise I can get equal volume between the two channels, but the volume knob has to be set noticeably higher with this input.
Switching to a different input without changing the balance or volume knobs from the setting for RI3 and LI3 leads to both a much higher volume and channel imbalance, with a higher volume in the left rather than the right channel.
I have tried to troubleshoot by reflowing the RCA ground tabs and center pins at RI3 and LI3, and have also re-flowed the relevant positions on the input selector switch (9 and 12 brown for the left channel, from LI3 and 6 and 3 orange from RI3). I also tried to reflow all of the joints on the balance and volume pots with no luck in fixing the problem.
Also, is it normal operation for the input selection when rotating clockwise to cycle through the inputs from outside (right) to inside (left)? I ask because this ends up with the knob turning in opposite directions of the position of the inputs, so for example when I have input 3, which is on the "left" or "middle" of the chassis being selected, the knob is turned all the way to the most clockwise or "right" or "outside" position.
Any advice appreciated
Alex
Alex
