Can I bypass the volume pot and turn Stereomour into power amp?
jerryZ
Hi,
I have been with my Steremour for about a year now, can't see enough good things about it!
I am adding a pre-amp into my system, and wondering if I can turn Stereomour into a power amp? I have the input selector bypassed when I built it,  and used an Alps blue for volume pot, can I just bypass the Alps Blue? or do I have to replace the pot with a resistor?
Thanks for your help!
--Jerry
Jerry,
I think this qualifies as a FAQ.  Yes, you can replace the volume pot with a pair of 100k Ohm resistors, or just run the volume pot wide open.  Either way you need a friendly load for your preamp.
(Grainger, that would be 100K ohms, not 100 ohms  :^)  <--typo
I suggest you leave the level control in until the system is in a stable configuration - it will be useful to trim the gain structure, depending on the actual sources and preamp in use. See my white paper on signals and noise, linked off the More/Community page.
Once stable and adjusted for best signal to noise, the control can be replaced with a pair of fixed L-pads.
Grainger and Paul, thanks a lot!!
My bad I should have googled,  this is really one of FAQ indeed..
