Finished my R monoblock and played in mono while I finished L monoblock. R amp checked out OK except resistance at B2 was 10.2k (both amps actually- specs call for 8.2k)- I don't think this is a problem. R amp Kreg A: 3.5V, Kreg B: 7.2- too far off? (specs call for 4.1V and 6.3V) I have Psvane 300Bs TII and GE JAN W5670s.
Anyway my main problem is wrong C4S board voltages on left monoblock. OA: 192V, moves around depending on trim pot position. OB: won't go lower than 185V with trim pot and I think was at 240V when I first fired up. Actually, OA and OB voltages rise and fall together with trim pot adjustment. Also, B side LEDs aren't lit up.
I was worried when soldering the C4S boards because it's hard to see solder flow like on the larger pads- since I wasn't sure about getting proper joint, I think I overheated transistors, LEDs, small resistors, regulators causing failure(s). Also, I think I should have changed to my 600F soldering tip. I'm getting ready to order parts right now- can't wait to hear them in stereo! Part kits available for C4S board? Or I can just order the suspect parts. Advice appreciated. Thanks, Kip..........
