Hello Bottleheads!
After nearly 200 hours of runtime with my amazing BeePree, the left channel has developed a very disturbing hum that is present after a few moments of power up and is audible at listening volume. It does not change with volume knob, and is present with or without sources connected, is unchanged between source selector positions and does not follow any of the tubes when I flip them from channel to channel.
I flipped it over and there are no signs of vented caps, burned wires etc, and a resistance and volt check shows that everything is still within spec. Thinking it could be power or amp related, I brought it to a friend's house and the hum did not change. Other than the tiniest of voltage present (few mv) on startup, there is no evidence of voltage across any of the inputs or outputs. The resistances for terminals marked "greater than 100Kohm" (OL) do not nor have they ever climbed above 40kohm but I think that may be my meter, and it is is very consistent across the whole build (IE both channels)
I'm at a total loss for what to try next and hope that a guru (or pack of gurus!) has a good suggestion or two!!
Thank you in advance,
Ewing
Ewing
