Thank you Paul and grufti.
The joint missing solder on the back of the B side filament board was actually soldered from the top, but I soldered it from below just now as well.
Thank you for spotting that.
The B-side LEDs are all still out, all four of them now, and the voltage at termnial 12 is 0.04V.
The A-side LEDs all come on, but then go out at the same time after ten minutes of power on.
The solderer is a 63 year-old man with vision impaired by a central retinal vessel occlusion in the left eye, not too proud to use magnification and loupes and direct overhead light.
Iron is a Hakko 936 usually set at 850F on the Hakko dial.
Soldering tip is a 1.5 mm "D" wedge, Hakko brand.
Tip cleaning with Hakko brass wool and a wet sponge.
Solder is Cardas quad eutectic flux core.
Copper wick method used to remove solder when necessary.
Knipex cutter used for wire cutting, stripping.
Appreciate your help,
Mark
Mark
