Bee pre Output upgrade voltage test
joralieu
Member
Just finished the output upgrade here are my voltage readings
45 6.9 VDC
60 7.3 VDC
46 214 VDC
51 214 VDC
Kreg 1.9 VDC
Kreg 1.9 VDC
Leds are all lit on the upgrade board but all out on the Bee quiet board.
Bee quiet upgrades have been working fine.
Well, the good news is that the output upgrade is unlikely to be causing problems. The bad news is that the high current C4S board as part of the attenuator upgrade isn't working properly. It is quite unusual to see super low voltages on the output terminals. If you run the preamp for a few minutes, then turn it off, are the big heatsinks on that board warm?
It might be possible for this to happen if you have removed the 300B tubes for the second upgrade and you put them back in but didn't get the pins in the proper holes.
What's the DC voltage between pins 1 and 4 on each 4 pin socket? How about from 1 to ground and from 4 to ground?
What are the OA/OB voltages if you disconnect the red wires leaving those solder pads?
