Well, the good news is that the output upgrade is unlikely to be causing problems. The bad news is that the high current C4S board as part of the attenuator upgrade isn't working properly. It is quite unusual to see super low voltages on the output terminals. If you run the preamp for a few minutes, then turn it off, are the big heatsinks on that board warm?
It might be possible for this to happen if you have removed the 300B tubes for the second upgrade and you put them back in but didn't get the pins in the proper holes.
