But if you use a capacitor with lower capacitance on the nF scale you could cut out frequencies above for example 50kHz. With the one I tried (22uF) with any frequencies above 45Hz would be cut away if I understand correctly?
This was done by calculating the time constant based on the resistance of 22kOhms.
