stereorob177
After a successful build, I'd been listening to my Crack/Speedball amp quite happily this last week or so. Tonight, no sound. Tubes heaters light up, but a peek underneath showed none of the LEDs glowing. Long story short -- I traced it back to the snap-in AC input/fuse holder. If the plug that's attached is stressed a wee bit one way, the LEDs go out and no sound, but enough voltage is still getting through to make the heaters glow a bit. Push the plug the other way a bit, the sound comes back and LEDs light up. "Hmmmm" says myself to me, "Dodgy AC input, loose connection". I see that the metal parts of the AC input thingy seem to be pressed together, so I heat up and add a bit of solder to all the pressed connections figuring one may have been loose. Also re-heated all the wire connection solder points.
Alas, I still have the same intermittent problem if the plug is pushed a little bit in this direction or that. I guess I need just replace the AC input/fuse holder. The question is should I request a replacement of the same part from the good folks at Bottlehead, or should I purchase a more robust part that fits the same chassis opening? Has anybody else had a similar problem, or do you think this is an isolated incident and a direct replacement appropriate?
I should also say this was the only hitch I've had with this excellent kit. I'm listening to it now as I type -- glorious!
Rob
Rob
