adding a mA meter to the Kaiju
Larpy
Member
I love the idea of adding a couple of mA meters to my Kaiju, but there's not much room under the chassis.  If I were to remove the input pots, is there a way to install meters in their place, or is that spot too sensitive in terms of picking up noise from the cathode?
If you are comfortable enlarging the holes in the chassis where the pots are, you could probably do that.  You'd have to relocate the pots or eliminate them from the design.
I added a couple of meters.  Pretty straightforward procedure.  Now for one last question:  both channels of my Kaiju have 72 mA of current going through the cathodes.  I assume that as the tubes age, the mA measurement will go down(?). At what point should I become alarmed and think about getting replacement tubes?
There are many ways a tube can fail. But if it is simply worn out, the cathode loses emission. An often used criterion is when the transconductance drops to 70% of new. For Kaiju, that amounts to about 4mA reduction in current. This is a small change and hard to see on a meter! Even worse, it's sensitive to power line voltage - a 5% change in the power line has the same effect as a 30% change in transconductance.
The reason it's so small is the self-adjusting nature of cathode resistor bias.
I have some very dead 300Bs that still draw about 70mA, it can be pretty tough to tell in a Kaiju!
johnsonad said:
Nice job Larry! That looks great and a really nice looking build!
Thank you, Aaron.  I still plan on springing for the Takatskis you recommended.  A matter of when, not if.
The MonAmour has a switch which changes the 2A3 plate current, and in the high-current mode it requires a modern 2A3 with higher plate dissipation rating than old-stock 2A3s. So the meter indicates the current to help prevent accidentally risking older tubes.
Thanks for the explanation P.J. That is a very useful feature indeed. You guys always think of clever stuff like that.
